Hello. having problems getting the timing set up on my 1600cc pinto.
It's got a ford distributor. I am happy that the basic timing of crank to
camshaft is ok. I am having some trouble timing the distributor I have
the engine running but when I put a strobe light on number 1 plug the
strobing is approx 30 degrees advanced. However if I put the strobe on
number 3 plug the strobe is at the timing marks. I have moved the plug leads
to suit but that didn't work. Turning the distributor to retard the ignition also does not
work. Reading the haynes manual states that the vacuum advance should face the rear
of the engine when fitting the distributor but I cannot do this because of the twin Webers
fitted. Any help/guidance would be appreciated. Thanks
having a 30 degree difference on what should be be the same point on the timing marks for cyl 1 and 3,
suggests something is very wrong, my initial guess would be the distributer shaft (the bit that triggers the points) being bent.
point or lectronic ?, if points i would say the dizzy cam is worn on one lobe , make some new marks for 2 and 4 and see if they vary as well
No 3 cylinder should be 180 crank degrees from no 1 , check the timing on cylinder no 4 which in theory should be the same as no 1 . If it isn’t then the distributor is worn/faulty
fitted.
I'd set the number 1 cylinder to TDC (confirm by putting a rod down the spark plug bore, it should be rising and both valves shut). Pull out the
distributor, enough to clear the drive cog underneath (mind there is a long hex drive to the oil pump) and rotate it till the distributer is almost on
the cam lobe for that plug, push it back down to reengage it. You might have to do this a couple of times as the drive cog is a helix, one tooth out
seems to be fine. There isn't really a particular terminal on the cap that is for a specific cylinder, it's just what works. Where the
vacuumed advance bellow is pointing is irrelevant.
Tbh with your setup I'd not even use the standard distributer and instead go for a full electronic one with automatic advance as your carb setup
is totally different now, correct timing has a huge impact on performance.
