I've booked and got a date for my IVA! Wait times are (for Beverley) currently:
Forms submitted online Wed 1st May
Application accepted today Mon 13th May
Test date Fri 12th July 08:00
Good luck, hope it's a pass or at most some very minor fails. It will be interesting to read your review of an up to date IVA experience.
Good luck with it all
[Edited on 13/5/24 by tegwin]
Originally posted by tegwin
Good luck with it all![]()
Good luck I passed my sva at Beverly Great day and good experience
Do you live near Beverly?
Graham
Tremendous attention to detail on that build. If you need any of the random IVA stuff e.g., the fog light control module to comply, send me a note. I was planning to put together a list to take to Malvern if people needed things.
Originally posted by christim
I'm interpreting my dash as 'non-rigid' as it's covered in vinyl, so will comply with a 5mm radius. If they say it's rigid and needs a 19mm radius it may not comply
The instrument panel lower edge within the "specified zone" must have a radius of curvature not less than 19mm or 5mm and be covered with a non-rigid material.
looks a really nice car.
WELL DONE
one iva point, I don't see any rear reflectors (red). unless they are part of the stop/tail lights themselves?
[Edited on 14/5/24 by gremlin1234]
WELL DONE
WELL DONE
Thanks!
Yep they're there built in to the outer light units, these from CBS
You've actually clarified something for me, this is the equivalent IVA statement;
It's almost like there should be a comma after 19mm if I understand your interpretation?
