A few tedious SVA questions in one, sorry.
Does the brake-test/indicator light have to be red AND have the recognised symbol on it, or will the word "Brake" on a label below any
coloured light be sufficient?
Do you need indicator warning lights for BOTH directions or will one lamp suffice, green?, with a double arrow or the word "Indicator" below
do?
Do switches on the dashboard, for FOG, for instance need to be illuminated for location, not for the indication they are on?
The reason for the questions is that I am trying to keep the dash layout minimal and was trying to use the existing warning lights on the Fireblade
clocks, re labelled or new legends , but i cant change their colours.
Thanks in advance
Colin
Does the brake-test/indicator light have to be red AND have the recognised symbol on it, or will the word "Brake" on a label below any coloured light be sufficient? Red and marked with the symbol
Do you need indicator warning lights for BOTH directions or will one lamp suffice, green?, with a double arrow or the word "Indicator" below do? One will do
Do switches on the dashboard, for FOG, for instance need to be illuminated for location, not for the indication they are on? No, just warning when in use
The reason for the questions is that I am trying to keep the dash layout minimal and was trying to use the existing warning lights on the Fireblade clocks, re labelled or new legends , but i cant change their colours.
Thanks in advance
Colin
Originally posted by snoopy
would say that these are probabley the easiest and minimalist way to go
bright6
But i`ve already got these
BTW Thanks for the quick replys
Something to do when Dr Who`s finished now!!!
I thought Dr Who was excellent!!!
BTW - the LED strip has a brake light included.
you could use these
Image deleted by owner
where can i buy that strip thing snoopy??
Regards,
TKS
premier do them
http://www.premierwiring.co.uk/
BRIGHT 6 WARNING LIGHTS £29.95 INC P&P
Look in the 'What's new' section
Jason
[Edited on 11/4/05 by Deckman001]
I got one of those last week. Nice little thing. Very small and compact, and incredibly bright! Was seeing coloured spots for a while after testing
it!
