Under dash
BMF - 23/6/05 at 06:23 PM
How much of the area under the dash do you need to cover for SVA?
How permenant does it need to be?
Any help appreciated!
JoelP - 23/6/05 at 06:41 PM
everthing must look perminant, for obvious reasons! they intend it to BE perminant!!!
i believe the full lower edge must be covered. not sure about stuff further underneath.
BMF - 23/6/05 at 06:45 PM
I have edging for the bottom edge, but I have a battery switch and a wood section I have rounded off which mounts all the wiring and fuses etc etc.
Does this need to be all covered up?
CairB - 23/6/05 at 07:01 PM
The underside of the dash being uncovered was a failure point at my SVA, due to 'sharp' edges on the fuse box under the dash.
It passed after I fitted an MDF panel that covered the whole exposed area from dash to underside of rail 'P' in Ron'speak.
Colin
BMF - 23/6/05 at 07:18 PM
Interesting, might do that, would make it tidier anyway.
Have people covered the ends of their shocks at the front?
mookaloid - 23/6/05 at 08:28 PM
Yep definitely
Mark
