is age relation worth it ?
Richard Y - 26/6/05 at 10:36 PM
im trying to decided if i should bother with the doner or just get the parts cheap from a scrapy but if i do then i wont get a v5 document so no age relation
so what are the benifits of age relation ???
is it worth it???
jonbeedle - 26/6/05 at 10:51 PM
Nah!
wilkingj - 26/6/05 at 10:59 PM
Visual Smoke emission only at MoT on a Q plate (but not so for the SVA).
stevebubs - 27/6/05 at 12:42 AM
And probably not for much longer at MOT, either
smart51 - 27/6/05 at 07:20 AM
Do you prefer a G plate or a Q plate?
will a future buyer of your car?
If so, will they pay more?
Would you rather have the rear axle from an xr4x4, the front from a 2.0 and the engine from a range rover (you should get a Q) or do you want to stick with a single donor and get an age related plate?
Personaly, If I cant have a new style '51' plate or newer then a Q is as good as an age related one, especially given MOT emmisions tests.
DarrenW - 27/6/05 at 08:44 AM
Im having same dilemna. Once car is finished i dont really want it to have a 1992 age related plate as the car is not 13 years old. Im thinking that a Q is as good as a private plate as no-one will really know its age. Now that we have SVA the stigma for Q's is not so relevant. The only people who will turn their noses up are non-car builders without the knowledge and these probably wont buy it anyway.
A Q plate with full photo build history and a comprehensive receipt file is surely worth as much as one with age related plate. Only downside is you cant retro fit a private plate later.
You cant see the plates when you are driving. Most other people will only see the rear plate for a small amount of time!!!
I still cant decide tho'!!!!
Richard Y - 27/6/05 at 09:21 AM
so when applying for the age related plate ?? is that the same plate that was on the done car
when getting the q plate what determines what it will say ???
the only thing i was thinking about was will it be worth more at the end if its just plain easier ill just go Q if theres no really benifits of age relation then i wont bother
im not sure bout the old pinto lump i had a quick look about no obvious ones for sale most are twin cam or have injection i was stering away from that for ease of fitting and less hassle but im defo going 4x4 rear axle and normal 2.0 front axle so would that effect age relation doesnt it have to be a certain amount from the original doner car ?
bimbleuk - 27/6/05 at 09:33 AM
While building my kit several people commented on the Q plate as generally people associate it with cars with iffy history.
So I got a V5 from a J reg Sierra and used Sierra bits for the transmission, suspension, brakes and steering. This was enough to get age related even though the engine was from a Toyota.
Though I got the V5 from RAW I'm sure they just applied for one from the DVLA (£19).
Hellfire - 27/6/05 at 09:43 AM
No - you will get a plate of the equivalent year. The old plate will be sacrificed with it's V5
Peteff - 27/6/05 at 10:10 AM
My car was given the donor registration when I registered it a Sheffield VRO. I was surprised when it came back with the same number.
nige - 27/6/05 at 01:21 PM
i have a 2.0 xe motor
a carlton box
a mk5 cortina rear axle
escort rack
mk6 essy columb and sierra hubs/brakes
mix mash mainly from breakers with no proof of age where do i fall in the great sceme of sva ??????? , helpful comments please...............
David Jenkins - 27/6/05 at 02:13 PM
Mine's a similar mongrel! The SVA don't care - but the DVLA will probably give you a Q-plate.
Not a big issue, as far as I'm concerned...
ReMan - 27/6/05 at 10:46 PM
I would like to keep my doner plate with its "MK" letters, I have the doner registered and SWORN'ed in my name.
Is there an issue here I thought you could use it?, along with scrapping MY car?
zetec - 28/6/05 at 02:41 AM
Always worth trying to "kid" the DVLA into letting you keep the donor plate, they have'nt a clue half the time when it comes to kits. If you want a age related plate get a V5 and say the bits come from it. Unless they know there stuff, and most don't, they go with what you tell them, although a bike engine from a Granada takes some believing!
I prefer a age related plate but just my preference.
