Many thanks for the diagram lifted off your site for the durite hazard switch.My wiring was exactly the same but the illumination lamp-ignition on would not work.AFTER TWO HOURS finally discovered when switch was built, lamp contact damaged!!.Tweaked connector ...sorted.Thanks for taking the trouble...Top Man
