I bought a Rover V8 some time ago; I never saw the donorcar, but it was a SD1, I was told.
What does the SVA wants from me when I present the car?
The V8 has double Strombergs with spaghetti waterpipes, it doesnot run very well on this set I heard, but thats another point.
A legitimate engine number with proof of age.
Pat...
Thx Pat
a) the engine number is stamped on the case: is that enough
b) proof of age: how should I know
Could you help me with that.
By the way :is there a list from Rover somewhere with gives information about the car age ?
I managed to find out the registration of my donor through LandRover traceability I just have the fax no. but not sure what you do with an SD1, as
mine was a Range rover donor, now rover are gone.
Dave
[Edited on 29/8/05 by V8Dave]
Rimmer Brothres used to have a table of engine numbers on their web site but the information seems to have vanished as I can no longer find the table
just refrences to it?
I LL find my copy later and post the numbers for sd1 engines -
Mr SVA will require more proof than this and I was planning to get in touch with him closer to the time to see what he requires as My ebgine is from
an 88 landrover.
This may help.
http://www.rimmerbros.co.uk/rimmer/land-rover/range-rover/eng-v8#Engine%20Numbers
The table is also printed in their V8 catalogue.
Thx for the replies guys, but I have still not the answer.
Rover V8 / not a Landrover engine !
engine number: 11A70537
above it: CR 9 351
.. and it was sold in the Netherlands. I can't check those numbers and the central Rover dealer is out of business.
any ideas left ??
They are very welcome !
According to the Rimmer catalogue 11A engines were fitted from 1976 to 1987 in SD1 automatics
Thx for help Snuggs; till 1987 taht's important
Automatic is correct..
I already have another flywheel and gearbox.
Another question:
The HTcoil Lucas 32C5( + and -) has some sort of electronic resistance box and that goes somewhere with 3 threads . I think to some starter key.
Do you know the conection of those threads ?
Good luck with your Luego Viento/lots of space !
