maybe a bit naughty but anyone know if the current SVA manual is online somewhere? (I have found a draft version which no longer is current).
My question relates to openings in bonnet, say you want to cut out a chunk so the carb air filters poke through. Is that allowed (must be as I see it
on many cars)? And any special treatment required to the edges i.e. trim?
Chester sportscars www.chestersportscars.co.uk
have a draft copy available to download. It is a March 2004 version. I don't know if this is current or not.
how often does the sva update or change I have'nt sent off my update form, do the basic rule like vehicle length/weight ect change???
If someone can host it, I have a current version (not a draft) which I can upload.
It is a good quality scan of the latest version. It is an 18Mb PDF file.
There are a few versions doing the rounds.
My suggestion is to get the newest complete version you can find and then cross refer that to the draft version for any changes. That way, you can be
sure your'e not missing anything overlooked in the draft version (which ultimately seems a bit pointless to have by itself)
Rgds
Rich
umm manged to find this...
www.rootpeg.net/WurzleGummage.pdf
The WurzleGummage version has 228 pages against the draft's 178, looks good
I have been reliably informed that there are a few changes to the Mar04 version that affect seven type vehicles. I dont have further details than that tho im afraid.
wow Mr Gummage certinaly knows a lot of ppl
Same version I've got![]()
