Rally Design Ltd now supply a document to all customers purchasing swaged braided brake hoses, stating facts supplied by Goodridge (UK) Ltd.
This document will be supplied to all future hoses supplied which are manufactured by Rally Design Ltd using the Goodridge swaging process.
The SVA requirements (VOSA) stated that the hoses need to have a tamper proof end fitting and therefore this document will only apply to hoses with
the swaged ends.
Any customers who have previously had swaged hoses can apply to Rally Design Ltd for this document by supplying the invoice number on which they were
originally purchased.
We hold large stocks of swage fittings and hose and have in house Goodridge tooling to produce them.
It is important that we all understand that hoses with re-useable ends are seen by the SVA process as not tamper proof and therefore will result in a
failure.
We hope this helps.
RALLY DESIGN Ltd
[Edited on 5/5/06 by rally design]
Re usable ends
my braided hoses just thread into the caliper and tighten with a spanner????
and the other end bolts together with the coper hose end
ta
chris
Originally posted by rally design
The SVA requirements (VOSA) stated that the hoses need to have a tamper proof end fitting and therefore this document will only apply to hoses with the swaged ends.
What do I do?
Seeing as my 'Goodridge' hoses - (like ZXR Locosts fitment) were supplied to me by Leugo!
Who are now Leu-gone!!!!
Will you give me the paperwork if I ask nicely
We have relayed the advice given from VOSA regarding re-useable fittings (socket & olive type) these are what they described as `tamper
proof`.
We would suggest in this case that everbody check locally this issue as there does appear to be inconsistent attitudes from testers around the country
regarding the rules on the hose ends.
Originally posted by zxrlocost
Re usable ends
ta
chris
As much sense as your Avatar!
Wibble!
A post so cunning you could put a cap on it and call it a fox from leicester
.........................So are re-useable Euroquip fittings classed as tamperproof or not???
I have them all round and I'm buggered if I'm changing them now!
Originally posted by muzchap
As much sense as your Avatar!![]()
Wibble!![]()
A post so cunning you could put a cap on it and call it a fox from leicester![]()
Well I emailed Goodridge and got a nice paper letter back (I asked for it in writing) saying their hoses were the best and were used in all forms of
automotive applications from road cars to racing cars blah be blah etc etc.
If you look in the Luego Manual they show the pipes being made up with re-usable ends, ie the fitting on the end of the pipe can be unscrewed and used
again.
These were very early ones, and Luego supplied me with crimped hoses already made up, and that was Nov 2004. They came in a Goodridge bag with Luego
Viento written on the label.
These are what the SVA people appear to be talking about. If you have the Swaged / Crimped collar types of fittings that are hydraulically crimped to
the flexi pipe they will pass.
This is what I read as being said.
Thanks to Rally Design guys for coming on the Forun to explain.
There are a lot if Luego builders who cannot get a supporting letter as Luego have ceased trading.
I think it a little unfair to ask the RD guys to supply a letter of compliance on a product they did not supply, and have not seen either. To do that
could leave them liable if your hoses are fitted with re-useable ends or incorrectly assembled by the builder. After all Brakes are "Mission
Critical" parts.. Dont take chances, and get it right first time.
IMHO... Take a piccy of them and Email Goodridge, as they are the manufacturer.
This is what I did.
b*ll*cks..........
(that is a general statement of my frustration and not aimed at anyone other than a SVA person)
This car building is starting to really get on my tits!
Why not just fit some cheap rubber flexies for the SVA that get replaced with braided ones when all that ugly trim/pipe lagging/rubber padding falls off?
because in principle i agree with SVA and understand the reason behind lots of the silly rules.
I'm not saying some bits won't fall off my car afterwards and if i'm driving then i won't cause a hazard to stop and collect them.
NS Dev - where are you going for SVA? My self assembly ones from Rally Design passed ok. The braking guys at work use the same type and that was good enough for me.
PS... Goodridge replied with snail mail letter, next day. I cant complain at all.
I take my hat off to the for the service.
Just drop then a nice well worded Email. keep to the point, and be nice and polite.
Been back to Gillingham for my retest today, all passed fine, apparently they have been in touch with Goodridge who have supplied them with the
paperwork to support suitable/unsuitable hoses that they manufacture.
Should make it a bit easier for those going through SVA in future.
Just thought I'd let you know the latest.
so are olive's / reusable fittings unsuitable?
What if i solder the fittings together? use threadlock?
its all b*ll*cks.
Yep, and as for cheap rubber flexies, try finding them with the right fittings each end, and then bear in mind that my stainless braided ones cost me about £8 each. They are not expensive, and they are a damn sight more convenient than the rubber crap unless you happen to have a crimper to do rubber hoses, as you can make the braided ones to the exact length you require.
I've used the Goodridge 600 series hose and fittings (supplied by Merlin MS) and these comply. This is what its says about fitting in the SVA
manual.
Yea, that's what my manual says! That is no problem as the reuseable end fittings have an inner support sleeve in them, so why the hell are
people getting pulled up on this one?????????????????????????????????
I seem to remember reading that someone got pulled up on this but had a spare with him and was able to demonstrate to the SVA man that it had an inner sleeve.
that was my plan - i've got enough bits for one extra that i can take with me and take apart. That way i can show it complies to that bit
........ but the act of taking it apart sort of ...... errm, means its not tamper proof.
Then again someone could just cut the rubber lines........ how do you stop that tampering?
Its the inner ferrule that is the important bit, as long as they have this, they are SVAable.
I had aeroquips from Rally design, pre made up (for a capri), and a spare end to demonstrate the ferrule if necessary at SVA. Terry at Exeter took one
look and said 'Oh those - Fine'
Spare end remained in my pocket
Ah, that's good to hear!
Got heaps of spare ones so will take one along with me to show them if necessary.
