Fuel lines - Exhaust manifold distance
nludkin - 21/5/06 at 06:25 PM
Does anyone know if there is a minimum clearance needed between rubber fuel lines and the exhaust manifold for SVA? The solid fuel lines are running down the opposite side of the transmission tunnel on my car hence the problem.
RazMan - 21/5/06 at 09:25 PM
If you have to go any closer than about 100mm I would cover the fuel lines in alluminium cloth to minimise any heat penetration.
