does this look OK, or will i have to raise the top mount???
top harness
top harness2
Ray
You'll probably have to do the measurements from the seat to be sure... you might be OK as you've got GRP seats.
On that topic, you'd better put some edging strip round the harness holes, as the tester may take a dislike to that fairly sharp edge.
rgds,
Depends where they are in relation to the seat squab/ base hieght.
But with unupholstered seats you should be able to wangle it.
I'd put edging on the seat hole as it may deemed sharp for the seatbelt and may lead to cutting or chaffing.
The edges of the seat belt shackles themselves were deemed too sharp at Shrewsbury VOSA , could injure somebody if you backed into them. 100mm sphere avoidance measures required to avoid contact
There is a diagram in this thread showing SVA dimensional requirements
http://www.locostbuilders.co.uk/viewthread.php?tid=19802
