Main Beam flash
r3nuf - 31/8/06 at 12:40 PM
Could anyone confirm if being able to flash high beam is an SVA requirement.
Have managed to get Luego loom to operate high beam via relay, but i seem to have a problem with the flash function.
Just wondered if i have to panic over this prior to my SVA on Wednesday?!
Gary
Peter M - 31/8/06 at 12:45 PM
No need to be able to flash headlights only that you can select main or dipped headlights.
graememk - 31/8/06 at 12:54 PM
so do you need to be able to flash for a mot
Just - 31/8/06 at 01:52 PM
No requirement for flash on MOT - only a main beam that can be switched on and off.
r3nuf - 31/8/06 at 02:06 PM
Thanks guys....
I will leave it as it is at the moment.
Just got to sort out the 1000 other problems i have, before wednesday, now.....
Gary
iank - 31/8/06 at 02:27 PM
Never found a flash on my Rover200, so unless the stalk is broken I don't believe it's a requirement.
JoelP - 31/8/06 at 08:59 PM
this seems to be a fairly common problem these days.
