getting worried about induction noise for sva test.
I have a plan of action to quieten the exhaust note for the test, (it is no doubt too loud) but sat in the car I can't even hear the exhaust over
the induction noise!!!!
Has anybody failed on induction noise.
If only the exhaust side of the car is tested I should be ok as the induction noise is obviously worse the other side.
They don't test induction noise at SVA as such. It's only the exhaust noise, although any external noise coming from anything other than the
exhaust may have a small affect on the overall reading.
Phil
I havn't got a copy of the SVA manual close to hand but it is measured fairly close to the exhaust so it will soon drown out any noise from the induction
500mm from the exhaust outlet and at 45 degrees.
You'd be surprised how much influence the induction noise has on the test.
Phil
You could try lagging the underside of the bonnett with fireproff matting to cut down the induction noise, SVA just measure noise per say so any noise
will get picked up.
Rich.
Are you in an enclosed space Nat, the test is done in the open at Derby and the noise is dispersed a lot more, not echoing off of next door's fence, garage wall etc.
IIRC it has to be done outside in the open
other thing is the throttles are not balanced yet (need to borrow your synchrometer Mike!) and that may be making them bark worse.
Haven't got an up to date pic but this gives the idea!:
progress1
[Edited on 15/9/06 by NS Dev]
Is this something XE's are known for? My XE on dellortos (45s) and a friends Caterham HPC on throttle bodies both make a lot of induction noise. Mine isquiteneed down by the bonnet though.
Originally posted by NS Dev
Air filter pokes out of the bonnet,
Put a temporary throttle stop on it
Don't fit a rev counter till after the sva test - they don't usuallyhave any means of checking revs so your judgement needs to be suitably
low.
