someone was aksing me about this - just got round to tkaing the photo
the mounting bracket/bolt is not SVA friendly on a lot of exhausts; here is my propsed solution.
An curved ali strip with a bit folded back on itself (so is like s 'T' with curved top) for the bolt is fitted; 8 mm round tube on the edges
- photo should say it all.
Will see if it gets through retest that I hope to do early in the new year.
[Edited on 21/12/06 by 02GF74]
That's very similar to mine. Should be fine.
i have used a rounded nut..
it has the same shape as a bolt/nut cap
in stainless offcourse
would that be enough??
Tks
don't thnk so - it is the exhaust bracket edges are a problem too - unless the shere doesn't contact them.
I did put a nut cover ofthe nut for SVA 1 that I have to peel off (melted like cheese
I did something like that on mine. Curved ali, fitted u trim to the edges and bonded it on with Wurth stuff. Passed no probs. Bracket is post silencer so doesnt get overly hot.
