headlamps
rpm - 29/12/06 at 01:44 PM
Hi all, anyone know if 4" diameter headlamps are ok for sva? i've just found some they've got main/dip beam and side light "e" marked glass all in a nice chrome unit and only £35 each
stevec - 29/12/06 at 01:46 PM
Do they dip to the left, If so then I cant see why not.
rpm - 29/12/06 at 01:49 PM
don't know, but the guy says he sells them to classic car people so i suppose they're legal for british roads
stevec - 29/12/06 at 02:14 PM
If you have to pass SVA I would try and make sure or it could be £70 down the tubes
Steve,
[Edited on 29/12/06 by stevec]
James - 29/12/06 at 02:19 PM
If they don't dip left then chances are you won't pass SVA.
They may pass MOT but that's a different issue!
Most of the 4" ones I've seen dip down not left as they are motorbike lights.
HTH,
James
rpm - 29/12/06 at 02:28 PM
ok, looks like i'll have to get back to him and check that out
Hellfire - 29/12/06 at 04:27 PM
The smallest diameter SVA compliant headlights you will find anywhere, are 5.75".
The smaller diameter headlights are not SVA compliant and will almost certainly fail without extensive modifications. By all means fit them after SVA if that's what you fancy.
If you want quality headlights or any other lights for that matter, you won't go wrong with the products that SVC supply.
SVA Website
Phil
