I would appreciate some help in sourcing a supplier of a chassis plate bearing the chassis number to satisfy our SVA man.
I believe the frame has to be stamped with the number too; is this correct?. If so will ERS take stamps without badly deforming.
Glad of your help and thank you in advance.
John
just get a piece of ally and stamp your own and rivit on or get a plate engraved at a local trophy shop or market stall (I used this option ) no probs at sva
Thank you Rich, much appreciated.
John
Like Rich says, piece of ally, get it stamped, rivet it somewhere visible on the chassis, cost a couple of quid at the most.
What about one of THESE
I stamped a piece of 18g and welded it onto the chassis as well as stamping the aluminium. Is a riveted plate considered permanent enough for the inspector?
My DVLA said it needed to be on the chassis in at least 2 places. Once can be a riveted plate, the other needs to be a permanent part of the
structure. The guy I was speaking to was happy for me to stamp it into the riveted and bonded ali floor though as the permanent one.
