is it 15cm or 30cm the line has to be secured.
30cm
Rich.
30cm, but I used 25cm just to make sure
Thanks Guys, i thougt it was 15cm for some reason.. that makes life easier now
Theres not actually a max specified in the SVA manual for brake or fuel lines, only for wiring.
In the case of fuel and brake lines the requirement is that they are 'securely' fastened. For wiring its 300mm max.
You are of course recommended to clip everything at intervals of less than 300mm just to be on the safe side!
