SVA fail at Brum
NeilP - 27/3/07 at 06:06 PM
Emissions (ECU isn't out of learning mode yet so hopefully a few more runs should sort it)
Rear brakes (must still have trapped air as calipers upside down - will have to invert them more and shake the buggers - handbrake was fine)
Bias bar lock pin (took the stuff but couldn't do it due to rears)
Couple of minor trim items under the dash
Speedo magnets need respoitioning at the input flange of the diff (on propshaft at the moment and clearly fouled the sensor on the drive over as had all been knocked out of position)
Retest booked for 18th April! Almost froze to death on the drive over but BLOODY HELL WHAT A HUGE GRIN I HAD IN THE RUSH-HOUR TRAFFIC!!!!
David the tester at Brum is a superstar - Couldn't ask to meet a nicer bloke - Took loads of time to explain and discuss stuff and you could tell that he genuinely wanted to pass it.
Right - Couple of piccies coming next (hopefully) - Then I'm off for a drink and a sit down as I'm knucking fackered...
p.s. He was fine with the one seat (don't ask) but did say that if the mountings were visible and available then strictly speaking they would expect to see everything fitted the seat...
NeilP - 27/3/07 at 06:08 PM
SVA 27 Mar 07 -1
SVA 27 Mar 07 -1
SVA 27 Mar 07 -2
SVA 27 Mar 07 -2
[Edited on 27/3/2007 by NeilP]
coozer - 27/3/07 at 06:15 PM
Nice looking car there... shame it failed.
Any chance of a picture of the front suspension? Just wondering how much 'cover' bits you have on there as he passed the front.
NeilP - 27/3/07 at 06:19 PM
thanks - As for the front trim the answer is not much and he didn't seem to care for anything behind the indicator (I hadn't even finished doing the small rubber U trim)...
SVA 27 Mar 07 -3
SVA 27 Mar 07 -3
John Bonnett - 27/3/07 at 06:21 PM
Neil, I would just like to say how stunning your car looks. A real credit to you and it will be ready to enjoy for the Summer.
alb
John
coozer - 27/3/07 at 06:22 PM
Cheers, surprised to see no cover on the shocker, but, there you go.
All the best for your retest
tegwin - 27/3/07 at 06:25 PM
That is a gorgeous looking car you have there!
jollygreengiant - 27/3/07 at 06:26 PM
Superb looking car mate. I trust you will be passed & bringing it to stoneleigh.?
Is it a Cosworth V6?
NeilP - 27/3/07 at 06:39 PM
Originally posted by jollygreengiant
I trust you will be passed & bringing it to stoneleigh.? - Acts of terrorism and the DVLA notwithstanding
In the words of Churchill, "...ohhhh yesss!"
John, Tegwin et al - Many thanks for your kind words - You can go a bit stir crazy in a 18' x 9' garage and it's only when you get it out in the sun (fog) that you can see if all the bits make a car...
24vseven - 27/3/07 at 06:55 PM
hi there stunning car
i am building a v6 cosworth locost just wondering if you ran into any problems with the engine install
would love a cpl of pics of underbonnet if you have any
cheers
BenB - 27/3/07 at 07:12 PM
I'd say congrats. As long as the emissions sort themselves out the rest of the problems appear pretty easy so here's to the SVA pass in a few weeks
NeilP - 27/3/07 at 07:38 PM
24vSeven
A couple in the photo archive and I'll get some more put in over the weekend.
The simple answer is tight (even in a Viento) if you are looking to get the negibe back as far as possible - It's a 60deg V so the heads come out quite a way and the bottom of the sump will easily go down 2-3" below the bottom rail assuming that your prop starts towards the top of the tunnel section. Therefore, where you put the triangulation pieces from the top side rail back to the bulkhead will be crucial. U2U "FUB" who has cut out a section of the Viento chassis to move the engine ever further back than mine...
24vseven - 27/3/07 at 07:56 PM
hi thanks for that i have built my chassis my self 6 inches wider than norm al i am a big guy so it all helps
is yours based on a boa or a bob
i have used a complete cosworth as my doner i notice you have 4 stud hubs did you use sierra stuff or late scorpio
hope to start trail fitting my engine soon and start makeing engine mounts
just checked pics boa i know
[Edited on 27/3/07 by 24vseven]
stevec - 27/3/07 at 08:49 PM
Very nice car,
I had David for my SVA at Brum and as you say, nice guy and wants to pass you,
Steve.
turbodisplay - 27/3/07 at 10:24 PM
How did you prove the age of the engine?
Letter from ford?
I`m using a boa myself as well.
Darren
NeilP - 28/3/07 at 09:26 PM
Donor was listed as 91 granny on form. He said, "It's a '91 then?" to which I replied, "Yes" and that was that!...
24vseven - 28/3/07 at 09:28 PM
hope i get it that easy
