Passed sva on monday 21st with a few minor fixes to be done (not enough sticky foam on the inside mostly) got an age related plate - brand new
Happy as larry at the minute.
Well done
Had a look at your photo's ,car look's mint
Well done that man
some photo's of the finished car have been uploaded, cheers for the support.
Is that a quik-releasable wheel?
Any chance of a close-up pic?
I'm specifially interested in how you made the horn work. I'm assuming it's the coil wire going into the dash.
Did the SVA inspector question the steering wheel at all?
Andy , yes the wheel is quick release but no the coiled wire is for the push button gear change on the wheel, not the horn.
Interestingly enough you dont need a horn for the sva.
All i did for the sva was stick some sticky foam over the metal centre of the whell and it passed.
Do you still want the close up ?
Hi Brooky
Where can i get an aeroscreen like your's?
How much did it cost?
And did it pass the sva with it on?
cheers Ian
Mr Loo the aeroscreen came from stuart taylor motorsport and I think it was 60 +vat
Andy it has got a horn its the little red button to the right of the temp gauge, but shall be moved shortly in the post sva deluge of work.
And the quick release thingymyooja came from rally design i think.
[Edited on 30/7/03 by Brooky]
Cheers Brooky, Rally Design is where I was going to get mine from.
I guess the coiled wire jobby could be used for the horn too? If so where did you get that from and how many connections does it have?
TIA
Cheer's
The coiled wire came with the klicktronic gear change system as did the connector but you can buy the connector from maplins (mine has 4 pins but you can get others)
