sharp Edges at the Front
The Baron - 14/6/07 at 06:49 PM
I had a little dabble when in got in this evening and have arrived at:-
[img]http://[/img]
Just need a bit of edge trim on the bottom shock absorber bracket, shrink my heat shrink on the track arm & a cap on the track rod end.
Hopefully I’ve not missed any thing obvious.
The stuff around the top joint and the shock absorber is some self amalgamating foam tape with insulation tape over the top to make it look bit nicer. The brake hose, where it enters the calliper has a length of radiator hose over it.
Also hopefully the cover I’ve put in front of the top wishbone bracket is acceptable?
All advice welcome.
The Baron
stevec - 14/6/07 at 06:57 PM
Looking good.
One thing, those indicators are the same type as i used and they were not the correct distance outwards, I had to make some extensions.
All the best.
Steve.
