Hi all, is there any reason these headlights would be a problem for SVA? have got a set of hella 90mm but found these 50mm to better suited very small
and compact.
Demon tweeks state that they are ECE approved.
As long as the beam pattern is ok (dips to the left) for the UK then it should be ok.
what are they and how do i find them on demon tweeks site?
http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=ROAD&pcode=HEL071-017
Should be the ones
Hella Catalogue Here... They are Quad lights
http://www.hella.com/produktion/HellaCOM/WebSite/MiscContent/Download/SpecialOE/L_Quad_2006_EN_HFA.pdf
a definite go for me, if they dip properly. fairly cheap (well, £230 for the set of 4...) the right size i need too. unless ford puma lights would
work for me.
anyone know if puma ones can be taken out of their mountings?
