Are there some letters / numbers that I am not allowed to use?
As far as I can tell from searching I can use a mix of letters and numbers upto a max of 17.
I am planning to pop into the local DVLA office next week to check if its OK..
Then fill in my SVA Forms!!!!!!
Paul
Old Luego gave me mine, might be worth giving Ben a ring? Just remembered there is at least two Viento's running around with the same vin!
[Edited on 10/8/07 by rusty nuts]
both of them the same colour as well!
VIN - making your own.
I make mine inthe airing cupboard.
OK I'll get my coat.
I presume that a kit comes with a number.
If you're go have enough points (conversion) you can use the donor VIN?
At last I presume that the DVLA, VCA or someone can give you an unique number?
ISO standard says no "I" and "Q" or "O" allowed. they could easily be mixed up with "1" "9" or
"0"
see also: http://en.wikipedia.org/wiki/Vehicle_identification_number
grtz
[Edited on 11/8/07 by t.j.]
The VIN should be exactly 17 characters - not 'up to 17 characters'.
I wrote to my local DVLA and offered them my proposed VIN - they wrote back and confirmed that it was OK.
Called in at the local DVLA and they said the number I had created was fine so now just need to fill in the SVA forms.
Paul
Smart-arse!
