Fuel Tank Mounting
Dave Bailey - 14/10/07 at 10:25 PM
Anyone know if the fuel tank has to be mounted with straps over the top or can it be bolted up through the bottom woth some welded lugs on the bottom?
Dave Bailey
bigrich - 14/10/07 at 10:29 PM
mines not a luego but is bolted through into rivnuts in the chassis. just needs spring washers on the secureing bolts and is sat on 2 strips of foam tape.
Rich
[Edited on 14/10/07 by bigrich]
DavidM - 14/10/07 at 10:30 PM
Yes either. Mine is fitted using straps, but others have used lugs and bolted direct to the chassis. Production cars have in the past used both methods also. There are no SVA issues either way.
Dave Bailey - 14/10/07 at 10:35 PM
Thanks Guys....
Dave Bailey - 14/10/07 at 10:38 PM
Rich,
Who made your tank? looks nice.. plus what pump have you got fitted? I have an impreza pump and sender that fits in the top but yours looks the biz!
Dave B
dan__wright - 15/10/07 at 07:57 AM
pump is 06/07 zx10r.
looks good rich, now i know what to expect what martyn has done mine, was it him that made yours? did it come with the lugs or did you ask for them?
DaveFJ - 15/10/07 at 08:26 AM
some people have suggested that welding lugs onto an ally tank and bolting directly to the chassis will lead to cracking around the welds due to vibration...
melly-g - 15/10/07 at 09:45 AM
I`ve got mine bolted direct to the chassis with rivnuts and spring washers, It`s a stainless tank with channel welded to the underside bolted through this. No problems yet!!
bigrich - 15/10/07 at 11:07 AM
Tank was made by bryn at Allyfab to my sizes
just gave him a drawing and dimenions. pump is from a zx6r but is the same as the 10r and regulates the line pressure internally so only one line is needed
it holds 4 gallons but needed to be smaller than normal to fit between the exhaust silencers in the back Rescued attachment fuel tank.jpg
Dave Bailey - 15/10/07 at 03:32 PM
Have I got this correct?
60cm * 25cm * 21cm is about 6.3 gallon tank?
bigrich - 15/10/07 at 09:50 PM
i make it 31.5 litres or 6.9 gallons if my maths is any good
