For the sva you need to have a demister on the windscreen.
Im going to be having a flat bottomed locost so the engine bay is going to be sealed.
can i duct the air from the engine bay up infront of the windscreen and say that will demist the windsreen (which it would i think?)
will this idea pass the test or not and has eney one tryed it.
the sva demist requires that the screen has enough air to clear it and the test is done statically so unless you plan to have a fan assist it won't pass
dam heated screen it is
why not try one of the small lecy demister blowers
If we go for a windscreen I'm definitely looking into electrical demisters after what happened to hicost..
put the fear of water into me.
the little lecy demister's you see in those cheap mail order catalogues are great. Stuck them in my friends mini and they demisted the windscreen
in seconds. Beats waiting for the engine to warm up before they work.
I've thought about ducting air from around the exhaust manifold too, so when your moving you can switch the heaters off.
Hmmmm, dodgy ground ducting engine bay air into the cabin,
Leaky manifold = Sleepy = crash
Colin
Be o.k. in a locost though, no roof.
yours, Pete.
Colin,
"Hmmmm, dodgy ground ducting engine bay air into the cabin"
It's how they did it on aircooled cars - just ensure manifold is sound, make a box around it with a fresh air supply (external) and some sort of
blower!
Call it a heat exchanger
Simon
Pete, if soft enought to want a heater then a roof has sure to follow suit!
I come from the land where the men wear skirts and no undercrackers, we know what cold is, no heaters for us must ba a southern jessie thing going
on!
1. Go to SVA with no windscreen at all.
2. Pass SVA.
3. THEN worry about screen, demisters, wipers, squirters, etc!!
You never know, you might like it windowless (get a helmet though!!), or grab an areoscreen (£20).
With an aeroscreen, do you still get rocks and bugs in your face?
My aerosreen is attached to my bashhat so s/be ok
Simon
what is a lecy dimister?
sound a bit poo coming avon or littlewoods
Had an idea would tape heating work if you run it along the bottom of the windscreen to heat up the glass ?
Rell,
Basically it's a 12v hairdryer that a) runs off electricity rather than using hot water, and b) looks nothing like a hairdryer.
Simon
Originally posted by Simon
Rell,
Simon
where do i get one of these gloryfied hairdryer from ?
