Morning all
Could anyone please advise on whether this rear view mirror will be okay and if not what's up with it.
If it could be temporarily modded to pass what would need doing?
Nigel
I used a suction cup mirror with no problem, but others have reported a fail because it could come off (I think).
The only other thing is that the clip gripping the mirror looks slight sharp edged... if you can't file it down, maybe you could disconnect it,
slide a piece of bike inner tube over it and glue it in place, then refit?
Also - where did you get it? I am still using the plastic suction cup mirror which works OK but is not as smart as yours - is it chrome or stainless?
I haven't bought it yet, wanted to check it was okay before buying.
www.holden.co.uk do a search for mirrors and it's on the 3rd page.
thanks for the input
Nigel
I'd suggest it'll fail due to sharp edges.
For SVA I used a little scuttle-top (bolted) mounted mirror. You couldn't see much with it because it was quite low down but it was there in case
the examiner decided I *had* to have one (not sure there's an SVA rule stating this but I've heard stories that some do). The wing mirrors I
had were suitably arranged so that all the tests could be passed with them alone and the wing mirror was mainly for looks.
After SVA I put a full screen on anyway and by happy coincidence the screen completely covered up the holes in the scuttle where the mirror had been
attached
I believe you have to have a rear-view mirror unless it provides no useful view to the rear (even if the other mirrors cover the viewing
requirements).
[Edited on 10/12/07 by matt_claydon]
Fails - radius I think - Dax use that one, but provide a plastic one to pass the test which then falls off and is replaced by that nicer one!
Chris
For SVA I used a little scuttle-top (bolted) mounted mirror. You couldn't see much with it because it was quite low down but it was there in case the examiner decided I *had* to have one (not sure there's an SVA rule stating this but I've heard stories that some do). The wing mirrors I had were suitably arranged so that all the tests could be passed with them alone and the wing mirror was mainly for looks.
After SVA I put a full screen on anyway and by happy coincidence the screen completely covered up the holes in the scuttle where the mirror had been attached![]()
Originally posted by matt_claydon
I believe you have to have a rear-view mirror unless it provides no useful view to the rear (even if the other mirrors cover the viewing requirements).
