hi can anyone tell me where i can get an sva guide car almost complete so need to start checking everything will comply.
Sean
Not sure if this is the latest... clicky
the one on the vosa site was not the complete version, if it were, they would not be asking £ 34 for it!!
It is out there on the web - if you still struggle, then u2u me with your e-address and I'll try to mail it to yer.
Indy Bird, you have a u2u
http://www.madmotorsport.net/SVA_Manual.pdf
also has the 2004 draft copy.
I suspect there is a more modern (ie non draft) copy in real life!!!
