Where can these be mounted to get through SVA???? Wanted to put it on the Dash but this I suspect is not acceptable also I have to mount an ignition
switch. I can get a switch with the correct radius but when the key is in it it will fail. Again where have people mounted them?
thanks
Dave Bailey
if you really want them both on the dash then fit them inside the 127mm exempt area around the steering wheel
I have an ignition switch on the R/h side of the dash and a cut off switch in the engine bay on the scuttle bulkhead panel
Within 127mm radius from the outer edge of your steering wheel, is exempt from the projections rule.
Somewhere there will be ok.
You could always have the cut off switch under the bonnet and connect it to a cable pull on the dash. I've done this on a few hillclimb cars.
