Hi i have been looking at the arditor and have come up with this, and i would like to no if it will pass the sva?
thanks
stuart
another view
and another.
thanks
stuart
Don't see why not
seems fine. good 1/2" clearance between parts. the pipe goes under the box with the pinion gear so steering arms won't hit of full compression or droop...
Nice and neat - no problem
just make sure that you fasten the hosing with some jubalee clips! dont want the engine over heating before you get to the test centre
Thanks i will buy a raditor and plumb that i like that, with clips.lol
stuart
i did mine similar to that, to help hold the hoses on you can either compress an olive on or solder part of a yorkshire fitting on, to give the
jubilee something to grip.
