Have I got it right ?
If I have a steering wheel of say 15cm radius the exempt area where I can put pointy things on the dashboard is a circle 15 + 12.7 cm radius centred
on the wheel hub centre ?
Or put it another way 127mm from the outside of the steering wheel inwards to the centre of wheel.
Well that's confused me
That ^^^ reads as if the exempt area is less than the area behind the wheel ??
Hah! Found a pic - sorted
Exempt area
Macbeast - yes, you are right per the diagram: steering wheel plus 12.7 cm
Peter M is confused
Think I'll fit a four foot steering wheel just to be on the safe side
After thought, I see what Peter M means so, OK
Humbug, sorry to miss you at Detling yesterday. I left just before the hailstorm.
