Do the instrument decals (main beam, brake etc) need to be on the warning lamp, or can they be mounted adjacent to the warning lamp?
cheers,
B
ill probably be corrected on this but i was under the impression that if the symbol was directly next to the lamp then it is fine above below left right you choose
was a ppost aboot this a week ago - the brake warnning lamp ust have decal on the lamp itself.
AFAIK the SVA manual doe not mention declas for the other lamps.
