anyone passed SVA with a full cage fitted?
anyone see any major issues?
cheers
Ray
I passed first time no problms with a full cage
Full cage is OK, the examiner moaned about getting in and out though.
Means you can mount the mirrors easily at the right height.
Just be aware of any bolts, sharp edges etc.
as long as its not make of razor blades and pointed sticks, then surely it safer that not having a full cage?
No probs here.
Pat...
First time pass in 2004 with one.....
No problem!...
Fozzie
just last week we had two that went through with full cages, only problem i had ( also mentioned above ) was mirror position as we have side doorbars
can can block some of the feild of vision if they are mounted on the scuttle, so had to move them to the cage uprights instead
cheers
marc
