fuel/brake line and loom fittings
Staple balls - 29/11/03 at 04:22 PM
what're the sva regulations regarding how all the wiring and fuel/brake lines are connected and attached to the car?
how often do they have to be clamped/attached to the chassis?
is it allowed to glue (well, sillycone goop) the pipes?
(specifically fuel) to the chassis (in the tunnel, along with other (probably jubilee clips riveted down, (is that allowed?))
anything else i need to know?
cheers
alex
Staple balls - 29/11/03 at 04:27 PM
oops, i was planning along the lines of this
along the tunnel. would that be ok?
theconrodkid - 29/11/03 at 04:53 PM
best to use "P" clips,every 11"fuel and brakes one side,electrical the other
Staple balls - 29/11/03 at 04:57 PM
yeah, thanks i got some P clips for brakes/leccy
but having trouble finding 15mm ones for the fuel line
[Edited on 29/11/03 by Staple balls]
theconrodkid - 29/11/03 at 05:16 PM
vehicle wiring products do most the things you need,have you tried them?
greggors84 - 29/11/03 at 05:32 PM
Thats pretty much how i plan to wire/cable my car. I posted a thread a couple of weeks ago about the same sort of thing and it sounds like this is the best way to go.
I used plastic p clips from premier wiring for brakes and will do for the wiring. I think i am going to use metal p clips with rubber inserts for fuels pipe. Just to be a bit safer.
Hellfire - 29/11/03 at 07:58 PM
We put fuel/brakes down OS and leccy down NS. Zinc'd with rubber for fuel/brakes and plastic adjustable for leccy loom... as on website.
bob - 29/11/03 at 11:55 PM
Try http://www.bluebeehive.com
or http://www.tifosi-devon.co.uk
I'm sure they have P clips in all sizes
SeaBass - 30/11/03 at 04:40 PM
Local Maplins Electronics will sell natural nylon p-clips, in a good variety of sizes. If you don't mind 'white' finish.
