I intend to as suggested cover the tops and bottoms of the front dampers with radio controlled car tyres, But would covering the entire damper with
front fork leg rubber gaiters (the type we used to cover the springs between the bottom yolk and top of slider on cafe racers) be acceptable.
Is it just the nut that needs covering between the swiveling arm amd the extention or is it from the track rod end to the end of the extention, was
thinking about using some radiator or heater hose same with the top ball joint also would I have to radius the ends of the hose.
thinking of using hose as I read somewere they don't like it to be cable tied as it could be interpreted as not being a permanent fitting.
also noticed some cars have passed the lower edge of dashboard test using titanfast is this now accepted by vosa
many thanks
tony.
just cover everything for sva, i didn't bother with covering the springs, the sva guy didn't even comment on it! make sure you take a bag full of trimming to the test station with you and the inspector will let you cover stuff whilst your there. if he's nice that is
I covered my shocks and mounti brackets with a long leather(ette) gaiter. Passed SVA in Aug last year with it and hav left it on.....!
we used glands as use by electricians
