If you go for an age related plate can you keep the no. of the donor???
started to get rid of an old car i was gonna fix up but its been lying that long its beyond redemption but i like the reg no.
if i say it was the donor can i get its number or will i just get givin a new one of same year??
AFAIK you get to have the age of the donor, but not the actual plate no
I have just done this (Thursday) you do not get the actual reg from the onor, only a reg from the same date, the reg will be a new one, ie it will
never have been used on another car.
B
ah well a Q will do
If you want to keep the no. you will have to transfer it to retention before scrapping it, get your age related plate (if you have enough points) then transfer from the retention doc to your kit.
at least with a q plate no need for emmision tests at mot time
think retention plate out of question car was last on road 10 years ago.
just sorta realised i got too many projects i wanna do and gotta stream line due to cost space an all the factors in reality.
and the fact that the mrs has given the okay to start a locost (as long as it gets space for the kids) so all the volvo runnin gear i got gettin dug
out and a lot of other stuff goin for scrap to pay for chassis was just hopin i could bluff dvlni that i used a different owner to get its plate...
i've heard they dont do Q plates any more for some reason or another.
could be wrong though
