cable protection
macspeedy - 3/1/04 at 05:58 PM
How much protection do cables have to have, will a plastic conduit in the tunnel do? I don't see the real necessity if the prop goes its going to go through a cable no bother.. conduit or no conduit.
David Jenkins - 3/1/04 at 08:02 PM
I used spiral wrap throughout - my philosophy is, if the propshaft lets go, the state of the wiring is a minor concern! I'll be more concerned about the state of my vital bits!
On a more practical note, the most convenient option is probably split conduit - dirt cheap and easy to use.
bob - 3/1/04 at 08:18 PM
I agree with david,split conduit comes in many sizes and is very easy to fit and add too as well.
Ben_Copeland - 3/1/04 at 09:18 PM
I'm with David and Bob too
JoelP - 4/1/04 at 12:37 AM
im with david bob and ben too
stephen_gusterson - 4/1/04 at 09:12 AM
For the prop shaft area (which carries all wires back) and the main loom to bonnet (carries wires forwards) I used plastic conduit.
This is because it allows extra wires to be added if needed without spending a month with spiral wrap.
Altho spiral wrap works well, it looks pretty crap, and I havnt seen it used much in the electronics industry.
Under the scuttle and in other 'short run' places, I have used 6mm and 10mm plastic sleeving.
Cable ties are used a fair bit behind the dash, to hold a mish mash of wires that head everywhere. Wires in this area are not ' exposed ' and the scuttle / dash basically forms a big junction box.
atb
steve
