Hi all
Just wondering what spring rates are being used on a sec raw striker, front and back,
I called martin at raw and wrote them all down , lost the damm bit of paper ,
So just checking before I ring him again and pester him,
[Edited on 15/6/12 by INDY BIRD]
I seem to recall mine are 280 front 200 rear...
Thanks for that as I have 180 rears and 225 fronts which I think is ok for road but not sure about track?
I think i run 250 front and 200-210 rear
So Mine seem a little soft then?
Thanks all
have you got those wheels on yet? photos
Bareing in mind mine are for Zetec engine with full cage.
225lb front, 180lb rear is "standard" .. For track, you could well do with 300+200 ...
Regards
I meant 250, not 300 ..
Beginning to think Im recalling mine incorrectly!
Upright mods being done as we speak, so should be good by tommo, only reduced the hole down by 6 mm to get clearance,
Fitted shortened springs and had to just bend a fraction the mandrake arm on the calipers,
Also a small trim of the outer end of the bottom a arm, ie one below the calipers, and should be good to go, no mods for rod ends required etc,
Tommo will be dee day,
I'll take some pics in a mo and post later of mods on chassis from prev post,
Thanks and I'll have to get some new springs then?
Sean
I have a set of raw spec track day springs 325 front and 225 rear
ps
not fitted but in the shed
[Edited on 15/6/12 by Dopdog]
Just thinking on this people seem to go too hard on the springs for track days. remember the suspension is supposed to move, its the shock that does
the work as well.
when I had the hard springs on it felt good I was used to it. Once I put on the softer springs and had the car set-up at Procomp I have never looked
back.
Just a thought.
I have 300 front, 180 rear at the moment.
Originally posted by Dopdog
Just thinking on this people seem to go too hard on the springs for track days. remember the suspension is supposed to move, its the shock that does the work as well.
when I had the hard springs on it felt good I was used to it. Once I put on the softer springs and had the car set-up at Procomp I have never looked back.
Just a thought.
Hi
Just to try and give you guys a bit off help.
What you have to remember is that at the front end with the inboard setup you need to know EXACTLY what the Dampers are doing in compression and
rebound. You can't go making choices on the springs if you have no idea what the Dampers are giving in compression and rebound.
Also remember that all the spring poundage's that RAW hand out for track use are from cars that have raced with totally different suspension
setups ARB's ( manufactured by me ) and Dampers that have been valved to work in that application not just Off the shelf items.
Cheers Matt
InterestIng matt that's put a spanner in my works, more to think about ongoing then I think I'll put it on track an see how bad it is and
what needs to happen,
Thanks for all your input,
Sean
Just a thought.
Maybe it's run the softer spring and invest in a anti roll bar to negate any body roll on track?
Especially on the wet I suppose you would want it softer to grip more?
Thanks again
Just a thought.
I tend to agree. All other things being equal (note this phase!) you want the softest springs you can get away with so the suspension does not hit the bump stops or ground excessively in critical parts of the road or track. As race tracks are generally smoother than the road (all other things being equal) you could argue that you run softer springs on a smooth race track than a road full of potholes and bumps......
I have a 900kg car and I run wheel rates of 210lbs front and 220lbs rear, (with 70mm of bump travel) but it does have a rearward weight bias.
Thanks again
Just a thought.
I'm not sure I would agree with this.
You need to keep the tyre's contact patch in full contact with the ground for as much time as possible A lot of sevens suffer with poor suspension geometry and high CoM which makes this difficult, hence the need to keep a reasonable stiffness in the corner springs / ARBs.
Also, the softer the springs, the more time you spend in transients. On circuits this is a definite disadvantage.
I did make quite a point of saying "All other things being equal" and obviously on these type of cars other factors come into play.
My way of doing suspension is to let the springs deal with the bumps, ARB`s deal with the bends and dampers deal with the transients. Maybe an over simplification........but a reasonable starting point.
I'm running 225 on the front and 180 on the rear. It does give more roll on the track, I think a striker can get away with that. I did install an ARB this winter but I haven't tried it on the track yet. What would be gained by going for heavier springs? Is it just to reduce roll?
its all gone a bit too complicated for me
its all gone a bit too complicated for me![]()
I'm using spax with 180lb springs.They are too soft for my lardy 16st arse.I've just collapsed the right rear,because they keep hitting the bump stops.I'm thinking of changing shocks and springs,but not sure what to and which rating....Any sugestions?
Ah I understand stand now
