Hi all,
Went to bleed the brakes on my recently purchased MK, one of the rear nipples is non-functional. I can't rotate it, have even tried locked mole
grips and they just "eat" into the nipple, it won't shift.
Is it possible to replace them? Sorry for the noobie question
TIA! Simon
yes they can be replaced if you cant get it out by unthreading it you could always replace the wheel cylinder not to expensive i have spare escort one
and cortina ones if that would help
cheers
colin
I generally find it's not worth messing about with that - if the nipple is that far gone then the rest of the wheel cylinder is probably not far
off being sha**ed.
Just buy a new one and fit it they aren't a lot of money and it's easy enough to do .
Mark
And don't forget to copper grease the threads on the new bleed nipple!
b0ll%cks, guess what I've forgot to do
Rich
Just bleed through the pipe --
Hold pedal down and close the nipple at the end of each stroke.
copper grease?? with brake fluid???
i would replace both sides then since the cilinders then are identical...
Tks
Hi
I had that problem so I replaced the other 3 and then gave the new owner 2 spare nipples for the one i could not get out
