I'm after a sierra or even a Mondeo steering lock. The bit that clamps the column, don't need the ignition barrel.
Plenty in the scrappy but all got barrels with no keys...
A bit more than just the lock
http://forum.wscc.co.uk/forum/index.php/topic/117492-steering-colunm-cw-steering-lock2-keysquick-release300mm-steering-wheel/
Hi Coozer
I'm working from memory here, but IIRC the Sierra steering lock worked by releasing a pin into a toothed section on the column.
Can we ask why you need one and what you want to achieve? There may be another way.
