Riv-nut Tool
gazza1591 - 25/9/11 at 03:42 PM
Anyone recommend a good riv-nut tool ? dont want to spend silly money but not a cheap on that will break the first
time i use it ?
thanks
Macbeast - 25/9/11 at 03:53 PM
Memfast
40inches - 25/9/11 at 03:56 PM
I have had one of These for about 3 yrs, has pulled dozens of 6mm steel rivnuts and still ok.
britishtrident - 25/9/11 at 04:04 PM
I have one of these Rivnut Rivetnut Nutsert Fitting tool M4 M5 M6 Kit car | eBay
Pulls the insert up nice and square to the surface.
bigdrew - 25/9/11 at 04:34 PM
I've fitted a fair few with no problems this way
mad-butcher - 25/9/11 at 04:59 PM
Make sure you use the serrated type rivnuts not the smooth, serrated ones are easier to pull into place and the serrations grip the metal.
[/img]
I use one of these about £50 but also does Pop rivets
tony
[Edited on 25/9/11 by mad-butcher]
lsdweb - 25/9/11 at 06:16 PM
I have the same as britishtrident and it is a really nice bit of kit - it's a little more fiddly than the normal type but gives you much better control - I also have a normal (like large pliers) type.
Wyn
Daddylonglegs - 25/9/11 at 06:41 PM
I've got one too. Used it loads of times and it's still going strong
trextr7monkey - 25/9/11 at 07:03 PM
and don't buy the CBS one, it did about 5 then the thread in the head stripped. pure sH1te
mrwibble - 25/9/11 at 07:25 PM
memfast.
cheapest one they do if your doing only a few rivnuts, they have an excellent one if ur flush, and plan on rivnutting the world.
stevegough - 25/9/11 at 07:38 PM
I also have one of the Silverline 'Pliers' type like 40 inches, but it is now on its last legs - the edges of the shoulder inside the head have become chewed - the lugs which engage in this slot have splayed slightly, causing the chewing. However, it had fitted loads of rivnuts before this started happening.
[Edited on 25/9/11 by stevegough]
