Help needed asap !!!!!
joolsmi16 - 16/9/10 at 06:57 PM
Hi all I am in desperate need of a wiring diagram for a c20xe dizzy engine...
The cars in the garage for the wiring to be done and they cant get a constant live to the ecu... and theres two men on the job thinking about it!!!!
Let me know if you can email me a copy
Jools
Wadders - 16/9/10 at 07:10 PM
Can't help with the diagram, but am guessing you want to know which pin on the ecu is permanent live?
you might get some odd answers otherwise!
Good luck hope you get sorted.
Al
]Originally posted by joolsmi16
Jools
joolsmi16 - 16/9/10 at 07:18 PM
Iam not sure whats need they say there a red cable that should be constant live and its missing from the loom.
I cant find a wiring diagram anywhere...
Jools
joolsmi16 - 16/9/10 at 07:26 PM
Knowing which pin on the ecu is constant live should sort it thou....
Wadders - 16/9/10 at 07:26 PM
If you just need a constant live feed, you can take one direct from the battery with an appropriate inline fuse fitted.
I think my ecu is fed via the ignition switch.
Al
Wadders - 16/9/10 at 07:30 PM
Google to the rescue, this might help
http://www.pngclub.com/forum/showthread.php?t=78214
or maybe here
http://www.migweb.co.uk/forums/engines-transmission/302252-c20xe-ecu-wiring-diagram.html
[Edited on 16/9/10 by Wadders]
joolsmi16 - 16/9/10 at 07:41 PM
just gave rodger a email so fingers crossed.
Thanks for link...
Wadders - 16/9/10 at 07:48 PM
Think this might be it
http://www.cavalierturbo.com/workshop_manual.php
RK - 16/9/10 at 07:49 PM
http://www.perfectpower.com/WiringDiagrams/SMT7/OPEL-VAUXHALL/Index.html
joolsmi16 - 16/9/10 at 09:01 PM
tried for the last hour to download the viewer ect from http://www.perfectpower.com/WiringDiagrams/SMT7/OPEL-VAUXHALL/Index.html
Can anyone save me a copy and send via email??
Jools
