Just need a couple of part numbers....
OK, list of required parts as I understand it:
Standard XE Cover Plate (Pressure Plate) - Early or late type dependent on what flywheel used.
Sierra 2.3 Diesel Friction Plate (Driven Plate) - Or another 23 spline plate (Check thickness).
Standard Sierra / Ford Release Bearing - QH CCT132??
RS2000 Clutch Fork
Vauxhall Spiggot Bush / Bearing - NUMBER??
Capri Short Adjustable Cable.
SBD / QED / Yukspeed Bellhousing.
Can anyone confirm the Ford release bearing number and let me know the Vauxhall spiggot bush / bearing number please?? I have most of the other bits.
I decided to go for a hydraulic clutch, so I have a clutch fork and release bearing for sale. I did fit it to my car, but I am still building it so it has zero miles on it. I bought it from Yukspeed for 57 pounds. You can have it for 35 pound posted to the UK.
Hi if you ring Yuk at Yukspeed on 01653618540 just ordered all the bits for mine. very helpful guy and good prices.
Also stevegough may be along in a bit to answer all questions.
Jools
Thanks chaps but I already have the fork and I have ordered other bits from Yukspeed and he is a good bloke to deal with but I just need the correct part numbers so I can go to my local motorfactors and pick up the bearings / bushes.
Try this link for all part No.s http://westfield-world.com/xeparts.html
Jools
Good link Jools!
Still not sure of the Vauxhall Spigot bearing number but that is a useful site.
Thanks.
Link for spigot bearing - QED motorsport
QED
Link to SBD site - spigot / release brg / arm
SBD
Sorry, Not sure of actual part numbers. - Got my clutch from Yuk. - I have heard the one about the 2.3D, too but not sure if it is correct - told Yuk
T9 to C20XE and he supplied the right one. Be careful - I ended up buying quite a few bits which proved hearsay to be sometimes infuriatingly
wrong.....
Just remembered - I have a new spigot bearing if you want - £6 posted.
Any more questions, ask away!
