Crossflow build
Marcus - 10/3/14 at 07:19 PM
As it was nice on Sunday, I had a day in the garage. Years ago I bought a freshly rebored 1700 crossflow block. I hava an old engine to be stripped for donor parts (crank, rods etc). The thing is, using the main shells from the old engine (just for a test fit) the crank doesn't sit fully into the block. The shells are marked 0.015 o/s and are original Ford ones. Is it possible the old block has had its mains bored out at production and oversized shells fitted?
as far as I can tell, the crank has standard sized Journals and the big end shells were marked A_A.
DW100 - 10/3/14 at 07:36 PM
Yes during re-manufacture it was not uncommon for the mains to be line bored and shells that were over-size on the backs fitted.
Marcus - 10/3/14 at 07:43 PM
Thanks for the confirmation, I thought that must have been the case. Just need to make sure I use the main caps from the newer block come build up time!
Need to get the crank tickled a bit to make sure it is round and buy new shells then put it all together
theconrodkid - 10/3/14 at 07:49 PM
dont use different mains caps,use the ones that came with the block.
as above,they are line bored and should never be mixed and matched
