Author: Subject: IVA - Immobiliser
Blackbird Rush
posted on 5/5/09 at 11:57 AM Reply With Quote
IVA - Immobiliser
It would appear that for IVA i will need to fit an electronic immobiliser, not a bad thing as it would hopefully reduce insurance premiums too.
Any recommendations for makes etc, would have thought min thatcham 2.
Also i need to show a fitting certificate to say its been fitted by a qualified person....... Any qualified auto electricians out there who would vouch for an installation for a few beer tokens?
tegwin
posted on 5/5/09 at 12:01 PM Reply With Quote
Going by the standard of "certified" installations I have seen latley I would imagine that a three yearold could claim to be your "expert" and sign the paperwork in crayon!
www.verticalhorizonsmedia.tv
Blackbird Rush
posted on 5/5/09 at 12:10 PM Reply With Quote
Stupid isn't it, we are building a whole car but need an 'expert' to fit the alarm/immobiliser.
Not specifically electrically qualified myself but i have made the whole car loom from scratch and they dont seam to be bothered by that!
With an imoballiser it either works or it dosn't surely the IVA tester can see its been installed correctly......
thefreak
posted on 5/5/09 at 12:25 PM Reply With Quote
Electric you say?
I thought that was only for cars without a steering lock?
vinny1275
posted on 5/5/09 at 02:12 PM Reply With Quote
If you read the manual, it says you can have mechanical or electronic, so key and steering lock are still fine. I think the difference between SVA and IVA is that *if* you have an immobiliser fitted, it has to be a certified install.
thefreak
posted on 5/5/09 at 02:14 PM Reply With Quote
<breathes sigh of relief>
Blackbird Rush
posted on 5/5/09 at 02:17 PM Reply With Quote
Yes, i have no steering lock thus need an electronic one......
[Edited on 5/5/09 by Blackbird Rush]
speedyxjs
posted on 5/5/09 at 02:50 PM Reply With Quote
2nd that.
big_wasa
posted on 5/5/09 at 04:44 PM Reply With Quote
I third that, sort of.
I have an imobilizer fitted but no certificate
I will just bypass it if I have to.
Dave Bailey
posted on 5/5/09 at 08:23 PM Reply With Quote
What about FIA switch under the bonnet, ignition switch but no steering lock.
Dave B
thefreak
posted on 5/5/09 at 08:36 PM Reply With Quote
I think it says if no steering lock then an electronically approved immobiliser has to be installed - not a kill switch
Blackbird Rush
posted on 5/5/09 at 10:53 PM Reply With Quote
I have an ignition key switch plus a kill switch under the bonnet but it would appear i still need an immobiliser......
Can get a cat 2 thatcham one for £50-60 just need to find an auto electrician...
alistairolsen
posted on 6/5/09 at 10:04 AM Reply With Quote
if your engine ecu came fromt he factory with an inbuilt immobiliser and you transferred over this and the lock ring,steering column etc and maintained its operability, would you still need a certificate?
In most cases it would be part of the unmodified engine loom.
