Author: Subject: induction roar...
spunky
posted on 23/4/04 at 08:05 AM Reply With Quote
induction roar...
Chaps,
A quick question.
There has several mentions of induction noise while undergoing SVA. What are the implications regarding the test.
I understood the only noise test was 101dB at the exhaust.
Reason I ask is I have two 62mm throttle bodies howling 10" behind my left ear...
John
David Jenkins
posted on 23/4/04 at 08:16 AM Reply With Quote
The only test they do is to stand a noise meter a fixed distance from the exhaust outlet, at 30 degrees to where it's pointing. If this meter reads over the limit then you've failed, whatever the source of the noise!
Incidentally, rally drivers have problems with their noisy gearboxes (straight-cut gears)! They get noise tested with their heels up and gears selected.
colibriman
posted on 23/4/04 at 09:17 AM Reply With Quote
2 thottle bodies? what engine you using...a bike twin?
i looooove the sound of a big twin and wishing i had picked one for my current project.....next time then......!
timcrasher
posted on 23/4/04 at 09:48 AM Reply With Quote
engine choice
Yeh, Spunky,
Is that a VTR/ Sp1 engine in your beast ?
It will sound like a lancaster bomber taking off when your flat out down the road!!
Awesome
Tim
spunky
posted on 23/4/04 at 10:50 AM Reply With Quote
It is an SP1 and it does sound a touch 'fruity'.
Gotta fit a different zorst and cat for SVA.
Reckon you'll hear me going up Beacon Hill Tim...
John
Brooky
posted on 23/4/04 at 01:28 PM Reply With Quote
They run the engine to 3/4 revs and test the noise then, but when i went for my sva the tacho was reading wrong. For some reason it thought i had 3 cylinders not four so it was reading high and when they revved it to 7000 sih rpm it was actually only doing 5500 - much quieter. i soon fixed the error when i left the sva centre (if you know what i mean )
alister667
posted on 23/4/04 at 07:48 PM Reply With Quote
Ahhhhhh! Interesting. Tell me just out of interest Brooky, what engine did you use, and where abouts did you look to 'solve' this 3/4 revving tacho problem?
Kitlooney1000
posted on 23/4/04 at 08:36 PM Reply With Quote
have the same problem on my revcounter too. it reads 6000 rpm at 70 mph, but the engine is not revving hard, so how to fix please.............?
TPG
posted on 23/4/04 at 09:36 PM Reply With Quote
Sva rev counter
At Beveley they use an independent clip on job rev' counter on one of the 'leads.........
..Which was nice..
alister667
posted on 24/4/04 at 02:04 PM Reply With Quote
The don't do that in N. Ireland. I'm dying to know how this is done. For academic reasons only of course!
http://members.lycos.co.uk/alister667/
Brooky
posted on 24/4/04 at 03:13 PM Reply With Quote
Its a fireblade engine and it wasnt really a problem, the tacho has a button to tell it how many cylinders the engine has - it then counts that many pulse etc. I simply told it i had a 3 cylinder engine for a while thats all. When i had passed i retold it i had a 4 cylinder engine. It was a scam to pass the noise regs.
alister667
posted on 24/4/04 at 06:08 PM Reply With Quote
I take it the tacho is not part of a set of standard blade clocks?
