-matt
posted on 4/5/10 at 12:46 PM |
age related plate?
im looking to build a MK Indy R.
am i right in thinking (after a bit of research) that to get a age related plate (Ie 10) you must use all new parts, and have reciepts for them
all?
otherwise you have to have a Q plate?
if so what do you do about engine/diff/hubs/steering rack Etc?
or have i got this wrong?
cheers,
matt
big-vee-twin
posted on 4/5/10 at 12:52 PM |
You get an age related plate by using a donor vehicle and using the 5 major components such as engine, gearbox, drive train, steering etc. Its based
upon a points system which you will find on the VOSA web site you will also need a V5 too.
Donors are usually a Sierra but MX5 is becoming more popular.
This gets you an age related plate same year as the donor.
A Q plate is on the same basis but with no V5
A new car is made from new ALL new parts - chassis, body, engine etc all which are available.
An one refurbed part as he says below
[Edited on 4/5/10 by big-vee-twin]
http://www.triangleltd.com
loggyboy
posted on 4/5/10 at 12:54 PM |
You need all new major parts except one that can be recondition (as new)
THe major components are:
Chassis/Body
Axles
Transmission
Steering Assembly
Engine
Suspension
Any further documentation of new parts used will aid the registration
details/form is here:
http://www.direct.gov.uk/prod_consum_dg/groups/dg_digitalassets/@dg/@en/@motor/documents/digitalasset/dg_065268.pdf
[Edited on 4/5/10 by loggyboy]
Hellfire
posted on 4/5/10 at 04:44 PM |
You have three options available;
1. A new registration - As Loggyboy suggests
2. An age related plate, based on the age of the donor vehicles V5 (If you have it) ie, a G reg Sierra will get you a G prefix plate but not the same
numbers and letters. To qualify for this you need to use 2 of the following components;
Chassis/Body Shell
Axles
Transmission
Steering Assembly
Engine
Suspension (front and back)
3. A 'Q' plate - using parts of an un-determinable origin, such as a vehicle with no V5 or parts sourced independently.
Phil
