Davegtst
posted on 6/2/11 at 11:57 PM |
IVA and ignition switch
I have an on/off 2 position ignition switch i wanted to use. The only trouble is you can remove the key both with the ignition on and off. Is this
likely to be a problem for the IVA?
austin man
posted on 7/2/11 at 12:10 AM |
would say so, I dont believeit is allowable for the enging e to still be able to run with the key removed after all the key is part of the
immobilisation of a vehicle
adithorp
posted on 7/2/11 at 10:34 AM |
Think you'd fail with that. I have a 2 position switch for my ignition and avoided ones like yours for that reason. Durite do a specific
ignition 2 position switch that the key can't be removed from in the on position. They're dearer than a standard key switch though.
http://jpsc.org.uk/forum/
Davegtst
posted on 7/2/11 at 10:51 AM |
Cheers, looks like i'll be getting a different one then.
