franky
posted on 24/3/11 at 03:35 PM |
Do you need tel-tale lights for indicators?
As above, I cant see it saying so in the manual. Anyone know for sure?
blakep82
posted on 24/3/11 at 03:46 PM |
required standard number 4
4.
There must be a audible or visual tell tale fitted to indicate the operation of any indicators such that would not cause confusion to the driver (see
note 1)
________________________
big-vee-twin
posted on 24/3/11 at 03:48 PM |
Yes, or a audiable warning unless you can see the front ones its on the first page-section 23
http://www.triangleltd.com
franky
posted on 24/3/11 at 03:50 PM |
Cool, a beeping flasher relay is in need then!
speedstar
If you DO want a tell tale, you only need one.
ie. it doesnt need a left and a right one
gavin174
posted on 24/3/11 at 03:51 PM |
I mounted side repeaters in the headlight bowls for IVA
I was told by examiner if I could see both of these from the drivers seat I was told I didn't need tell tale,
But had one on the acewell as well
adithorp
posted on 24/3/11 at 03:52 PM |
Will it be audible over the engine/wind noise? Don'tknow if that would count as a fail though, but why risk it.
http://jpsc.org.uk/forum/
franky
posted on 24/3/11 at 03:54 PM |
Scrub that, I'm an idiot, i've already got warning lights fitted
rodgling
posted on 24/3/11 at 04:54 PM |
That's an easy fix then :-)
franky
posted on 24/3/11 at 05:13 PM |
The first of many! Pre match nerves I think
wicket
posted on 25/3/11 at 11:42 AM |
You'd need to be a bit of a contortionist to be able to do this !!!!
