davidimurray
posted on 20/7/13 at 09:34 PM |
Pre-IVA Photos
After a week off working in a boiling garage I think I am just about there. Going to make a start on the paperwork this week so thought it would be a
good idea to post a few photos up here. Would be great if you could have a look through and see if you can spot anything that needs attention. Jobs
still to do are :-
Trim headlight lower ring
Fit under dash covers
set headlight alignment.
Make some covers to go over upper seatbelt mounts
All advise gratefully received
Dave
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
loggyboy
posted on 20/7/13 at 09:52 PM |
Looks good, nothing glaringly obvious.
Mistral Motorsport
Mr Whippy
posted on 20/7/13 at 10:16 PM |
I think you have done a very good job
big-vee-twin
posted on 20/7/13 at 11:19 PM |
Need to remove windscreen wiper switch as you have none fitted
http://www.triangleltd.com
Mr Whippy
posted on 21/7/13 at 03:25 AM |
Really? Is that not like having extra harness mounts but failing cos you've fitted 3 point belts...
Chris_Xtreme
posted on 21/7/13 at 07:14 AM |
Looks very tidy indeed
The base of the headlight might need a bit of trim if you can get there with the knee shape thing.(the very bottom of the fitting)
I'm sure you have but make sure the foglight is vertical.
I dont think you will have a problem with the wiper switch being on the stalk. My friend left it in place and was fine, however may be down to the
inspector so i would be ready to remove it whilst you are at the test in case thats it.
Smoking Frog
posted on 21/7/13 at 08:58 AM |
Do you have enough clearance around steering gaiters when suspension is at extremes. Looks a bit tight but could be the angle of the pic. I'm
struggling to find anything, tidy build
davidimurray
posted on 21/7/13 at 06:26 PM |
Thanks for having a look every and for the compliments.
I will keep a hacksaw blade handy for the iva in case the inspector has an issue with the wiper stalk.
Headlight Trim is on the to do list.
Steering gaiters is an interesting one, at the moment they clear, just .... Think I might get the nibbler out to be safe.
loggyboy
posted on 22/7/13 at 10:21 AM |
I guess it comes down the 'not cause the driver confusion' interpretation
Mistral Motorsport
blakep82
posted on 22/7/13 at 10:45 AM |
And I suspect a tester could think if you have the switch there, you might be intending to fit a windscreen later, but just didnt want it tested
(because you'd have to fit heaters, washers etc) sort of a bit like fitting lights, but not actually having them wired up, makes a bit of
suspiscion?
Otherwise looks tidy. Are those gaiters on the wishbones clamped on? Clamps might make them look a bit more permanant
________________________
Chris_Xtreme
posted on 22/7/13 at 02:06 PM |
yep - I was thinking down to 'you will be going to fit a windscreen then.....'
IIRC you can unscrew the back of the sierra stalks and remove the one in question with out damaging anything... maybe do that now upfront if you have
the time.
cheers, Chris
v8james
posted on 22/7/13 at 03:36 PM |
Looks great
What nose and bonnet are you using?
Jimfin
posted on 22/7/13 at 07:39 PM |
I passed with the wiper stalk in place (2012), same set up as you with no screen.
davidimurray
posted on 22/7/13 at 09:33 PM |
Thanks for all the advice everyone.
I've bought another set of stalks for the wipers so I have a spare for future and I will cut off the current stalk just in case.
The gaiters on the wishbones are ziptied in place with some black ties, they are tight enough that I cannot slide them along the tube.
The fibreglass is all from Saturn Sports Cars who are sadly no longer trading however I believe the moulds have passed on to another company but
cannot remember who at the moment.
Thanks again
Dave
davidimurray
posted on 25/7/13 at 09:56 PM |
Iva forms now in the post so no turning back. Just the last bits to finish off now.
SteveWallace
posted on 26/7/13 at 09:10 AM |
Front flexi brake lines look like they might touch the wheels on full lock. This might just be perspective in the pictures though.
davidimurray
posted on 27/7/13 at 08:17 PM |
Just a brief update on progress.
Finished trimming the front headlights. I also wasn't happy with the adjustment nut being right up inside the mount, meaning I had to disconnect
the wiring and use a deep ring spanner. Made a spacer so the nut is lower down and I can use an open ended spanner to get to it.Then used some rubber
cable gland covers to cover everything.
I've also cut the wiper stalk off and glued the end of a cable gland over it.
Found a bit of trimming I had missed .... the nut on the bottom of the centre mirror!
Currently finishing off the vinyl on the covers to go under the dash.
And Mrs M is making sewing up some covers to go over the upper seatbelt mounts.
Had a mild panic today when I realised the drivers side headlight seem to have no beam pattern. Unit was exactly the same as the passenger side so
stripped it and found the bulb wasn't seated properly. Re-seated and beam pattern came back - phew
Hopefully will get a few hours with the manual tomorrow and check all the detail again.
davidimurray
posted on 16/8/13 at 07:08 PM |
Having submitted my iva forms 3 weeks ago i've been chasing vosa through the week, forms were passed to local test centre on Monday and they
said to ring back today if I hadn't heard anything.
So rang back today and after being passed back and forth for about 15 min they eventually put me through to the test centre as they were not allowed
to give me the direct number. Spoke to a very nice lady who explained that a guy called Bob Stafford does the tests and that he organises all the
tests and paperwork so would need to speak to him. Only problem is he is very busy doing tests and rarely in the office so she gave me his mobile
number Slightly worried when his number had 666 in it! Gave him a ring and had a nice chat.he explained how busy he was and that earliest possible
date would probably be around 2nd week of sept He even asked what day I would like, when I said any he cheekily replied 'is the right
answer'.
Feel a lot more relaxed after chatting with him and in his own words next time I speak to him will be to give me my test date.
