Author: Subject: Handbrake Issue
Jamesc
posted on 19/1/15 at 01:07 PM Reply With Quote
Handbrake Issue
Good afternoon..
After a month or so absent from building, I thought I'd have a day in the workshop - About an hour in and I was stumped.
Can anyone suggest a solution (or tell me what's wrong) for the handbrake cable routing on a Spire GTR using Sierra calipers? At the moment, it looks like below and will require a sharp 90 deg angle to get it round.
That is not the cable I'm going to use by the way as it's a standard sierra one.
Thanks, James.
CosKev3
posted on 19/1/15 at 03:31 PM Reply With Quote
Swap the calipers onto opposite sides of car?
loggyboy
posted on 19/1/15 at 03:38 PM Reply With Quote
/\ This /\
Mistral Motorsport
designer
posted on 19/1/15 at 03:46 PM Reply With Quote
If you have to turn it 90deg. use a bell crank. You can also put in some mechanical advantage.
theprisioner
posted on 19/1/15 at 04:17 PM Reply With Quote
Can you not make a bracket, attached to the existing handbrake outer sleve capture position and shift it inwards by 20mm. Then modify the leaver.
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
Jamesc
posted on 20/1/15 at 09:15 AM Reply With Quote
Cheers for the suggestions
I'm trying to avoid having to make a bracket or extension etc, as surely it should fit!
My only thought was to space the caliper out, but then I'd need to space the disc and fit some different offset wheels..
Would the above picture be an IVA failure as it is touching the lower arm?
theprisioner
posted on 20/1/15 at 10:35 AM Reply With Quote
If you look at either the VW Golf or Passat calliper as fitted to Westfield's and Sylva J15's they have possibly a more sympathetic handbrake cable exit for your suspension design. It may be worth a look.
Jamesc
posted on 20/1/15 at 12:01 PM Reply With Quote
Cheers mate. I've checked them out and they look like they may work better.
I'll do some more research in to that.
CosKev3
posted on 20/1/15 at 02:44 PM Reply With Quote
Just swap them side to side!
the cable will feed in from the top then like the majority of kit cars using sierra calipers
Jamesc
posted on 20/1/15 at 02:53 PM Reply With Quote
I did consider that, but does it make bleeding them a pain?
Also, most Spires I have seen have them installed as I have, so I'm a bit miffed.
mark b
posted on 23/1/15 at 10:20 PM Reply With Quote
Remove the mounting bolts bleed that brake and then bolt it back on
AntonUK
posted on 24/1/15 at 09:53 PM Reply With Quote
mine are just upside down, bleeding is a pain but not done often
Build Photos Here
