phil clegg
posted on 22/7/15 at 07:53 PM |
bias brake sticker
I have read that a warning label of some type is required for the adjustable bias.i spotted a nice one on here from a fellow locoster,he had non left
so I have had mine made plus a few more if any body needs one,these are 95mm long and26mm wide,they are are made like the chassis anty tamper stick on
vin numbers like many French cars.they are yellow with black letters,£5 inc post,i they say,adjusting front to rear bias may invalidate approval and
breach construction and use regulations.
jossey
posted on 22/7/15 at 09:10 PM |
It doesn't require a sticker just need fixing so it cannot be adjusted.
Lock nuts are accepted in some centre but wiring is the best way. Drill a hole through just behind the nut and wire up.
I haven't seen anything about labelling...
Note 5: Bias bars and other mechanical adjusting devices fitted to twin master cylinders must be rendered inoperable by mechanical means e.g.
lockwiring of components.
David Johnson
loggyboy
posted on 22/7/15 at 10:15 PM |
27. Vehicles fitted with adjustable twin master cylinders that have been rendered inoperable by mechanical means to comply with RS 26 must have
a label affixed on the master cylinder or the immediate vicinity with legible text as detailed in note 6.
Note 6
Adjusting front/rear brake bias may invalidate approval and breach Construction and Use requirements.
Mistral Motorsport
jossey
posted on 23/7/15 at 06:06 AM |
I stand corrected
I'll have one then lol
David Johnson
adithorp
posted on 23/7/15 at 07:27 AM |
Jossey, The sticker requirement was introduced when they dropped the requirement for the adjuster to be permanently locked (soon after IVA came in).
http://jpsc.org.uk/forum/
Daf
posted on 23/7/15 at 08:10 AM |
I'll have one please, u2u on the way
Lander
posted on 24/7/15 at 09:40 PM |
I am now confused. So can I fit a manual bias adjuster in the rear brake line?
adithorp
posted on 24/7/15 at 09:50 PM |
No.
Lander
posted on 24/7/15 at 09:53 PM |
Good. That's what I thought. Thanks.
